1mm or 1.5mm T&E for standard lighting circuit in your average house. | on ElectriciansForums
Discuss 1mm or 1.5mm T&E for standard lighting circuit in your average house. in the Lighting Forum area at ElectriciansForums.net
1mm or 1.5mm
  • 1mm T&E
    Votes: 61 62.2%
  • 1.5mm T&E
    Votes: 37 37.8%
  • Total voters
    98
Shirley (!) you use a cable suitable for the design, not 'cos of its physical size?
If it satisfies the design then using size as a consideration is legit Shirley ?
I use 1.0mm almost exclusively, and the reduced size helps considerably on most rewires. Never have a problem with design considerations.
Me thinks you misunderstood my post?
Reply to 1mm or 1.5mm T&E for standard lighting circuit in your average house. in the Lighting Forum area at ElectriciansForums.net
Yes I understand the setup now. Sorry about my confusing first post 🫢 It might be worth buying the Livolo switches you identified and lash at...
Thanks for your time and opinion.
