You couldn't totally assume 1.0 is ok in all circumstances you could invent. Never mind volt drop for now, but if there are 20 circuits bunched in 50c ambient under insulation you'd have to do a bit of redesign.
Agree hence the caveat about"circumstances you could invent" as it's not realistic to encounter that!We are talking about an average house.
Maureen, I need a hand down here....pint or a half![]()
No but go on......
Agree, sorry wasn't disagreeing with anyone, just trying to add somethingI don't think anyone is assuming that.
Another point is if you might want to repurpose some of the cables in future as "power" instead of "lighting"you'd be better with 1.5
I've often thought I'd be better off without lights and having sockets on the ceiling instead![]()
Perhaps John is older than me (but younger than Tel), when we did just that, plugging the iron into the lighting point.
I used to mainly use 1.5mm, but due to LED lighting now mainly use 1mm
10-15 years ago everyone suddenly started wanting loads of GU10 down lights in each room. Even though 4 would be ample, customers wanted 6,9,12 down lights in each room. This was when you would use a 50W or 35W GU10. Added to that the wall lights the loading soon added up. As I said in my post when people started using LED the loading dropped dramatically.This kind of statement never makes sense to me, the average domestic lighting circuit is put on a 6A mcb with cable size calculated accordingly.
