Pete999
Like the title says, I think it may have been posted before many moons ago. 1st fixing bac, boxes I used to bed all my boxes in with bricklayers compo ( the stuff they lay bricks with) wait until it sets, if you have time, and then drill and fix with rawlplugs and screws, how or what method is the trend these days?, not talking about fast fix boxes either.
I always mark up and drill and fit the plug then use thistle bonding push the box in and tidy up and screw back then screw a small piece of battern across the front to level with the existing wall till it dries tidy up with some fine fill....f I’m in a hurry I mix a bit of rapid set cement in with the bonding......
I just set them in with bonding, no other fixings. I do make sure the hole is very wet with a sprayer and PVA if particularly crumbly.
Normal fixings for me.
Although I do recall a particular site, where some flats had 100mm partition walls. So we knocked out holes for back boxes, fixed em to battens face side, and mortared rear side. Dread to think what those Luton apartments re like now!
I like to bed em in. Drywall adhesive that's been sitting in the garage for nearly 2 years - rock hard after 1 hr and very strong hold, no screws needed. Bit 'slumpy' though.
Easifill 20 if in a hurry, no slump and can sand back easily if required.
I imagine thistle bonding 60 would be useful too, though I've only used it for plastering as yet.
Thistle bonding with a handful of extra rapid cement will get ya out of trouble :).....I always pva first and always plug and screw sockets, don’t mind just bonding light switches though...
plenty other versions out there!
Just choose the right thickness of "biscuit"...it comes in "sitcks" so you can slice off the depth you need...
Once set, screw through the back...job done!
Steal some mortar mix from other trades throw a bit in and set the box to your liking. Or if the chasing has been done to a good standard and the box will sit flat a couple of screws and wall plugs
Surface mounted pattresses and MT2 for me Pete! And only the sticky backed type mind ! Don't have to faff on charging the batteries for the drill as often either !
Pete999
Northampton
Retired Electrician
Business Name
None
1st fix metal back box fixing, how do you do it?
Pete999,
NDG Elecs,
