R
rob675
Hi all,new on here just after some advice.I have my first job starting at the end of the week,i have been to look at it it is installing 4 downlighters and a extractor fan in a repositioned ensuite.I am planning to extend the original lighting circuit to use for the lights/extractor-i take it this wouldnt be classed as a new circuit? also as its supplying a bathroom im assuming it has to be rcd protected?if so again im assuming the cable in partition wall/under floor and ceiling wont need mechanical protection.The cu is directly below this room so not a long run i take it 1mm t&e is ok?
As im not registered to a scheme yet i have had to go down the building note route,they have said i can do the work-test & certify they will just come round and check it before they sign it off,does anyone have any experiance of this?I know theres allot of ? just want to get things right first time.
