J
james king
Hi all, was wondering what your thoughts are on a CU upgrade....At the moment it's got 2x CU one supplying the flat and the other the heaters! Now can I install 1x 10 way split load RCD protected CU and use one side for the house and the other side for the Heaters? Taking out the live and neutral link from the other rcd and use the 2nd supply for the heTers?? So there for having two supply's in one CU???
