2.1Ah battery | on ElectriciansForums
Discuss 2.1Ah battery in the UK Electrical Forum area at ElectriciansForums.net
Ross1
Hi guys, can i fit a 2.2Ah battery into a alarm unit that states it requires a 2.1Ah battery ONLY?
As long as the voltage is correct then it will be fine. The ampere hour rating isn't too critical, it dictates how long the system will run without power before the battery is flat. The ampere hour rating of a battery decreases as it gets older so it's a variable in real life conditions.
I'm not sure why they suggest an exact value rather than saying 'at least 2.1Ah'. Three weeks from now your 2.2Ah battery will only have 2.1Ah capacity anyway. I wouldn't worry.
only thing Id say is check the physical dimensions as My gaffer told me to get a 3.8 rather than a 4Ah BUT the 3.8 is rectangular the 4 is more cube like and space wouldnt let the 3.8 fit
If the electrical specification is similar, a larger Ah capacity is a bonus. The physical dimensions, terminal type and position are usually more important parameters in this case when sourcing a replacement battery.
I've got a battery question, which I think I might as well post in here...
I've been given a load of 3.6V 3 cell 4Ah battery packs to replace existing 2 stick 5 x D cell 6V 4.5Ah in some emergency light setups.
Ah rating is not the issue here, but the voltage is and considering the newer packs require less voltage they should work fine with the existing setup shouldn't they?
I guess I would expect the light to work off 3.6V.
It's more reliant on the switchgear (ballast) I would have thought. As long as the battery pack fits within the range stated on the emergency light ballast it should work, should it not?
Reply to 2.1Ah battery in the UK Electrical Forum area at ElectriciansForums.net
Indeed. And always worth giving the batteries a few spins while in place - sometimes cleans the contact areas up a bit.
It’s getting to the point where full LED replacement is cheaper than spending time on testing and possibly replacing parts.
