R
ron55
Does anyone know when they stopped making 2.5 T&E with only a 1mm earth wire?
Cheers, Ron
Cheers, Ron
Discuss 2.5 Twin & Earth - earth size 1mm in the Australia area at ElectriciansForums.net
about time as well. the number of times i've hit myself in the face with sidecutters stripping the damn stuff and the 1.0mm cpc snapped.
Same here
Does anyone know what the reg say about doing a csu change when this wire is used ?
Why the age?? ....1981?? Will probably still be good, when you and i, have long since departed this earth. lol!!!
Condition of cable, ....well that's another matter!! lol!!
In 35 years I’ve never seen the dreaded green goo. It’s copper oxide! Only caused by bad connections and heat, bad workmanship!No way of telling a cables age, and being PVC insulated and sheathed, there is no real life expectancy. Depends very much if the cable has had a hard life, such as being constantly overloaded among other things. Cables that have led an easy life installed in correctly etc, you would hardly know how old it was. The only other thing from that sort of era, is the ''green goo'' syndrome. Certainly i'd be changing them ...lol!!!!
a bit like me thenThe condition is of course the key factor but keep in mind that that cable was around in the late 1960's and could easily be in excess of 40 years old, well past the expected safe life.
Reply to 2.5 Twin & Earth - earth size 1mm in the Australia area at ElectriciansForums.net
