Hi all what would be the best option. A client has an existing armoured cable that is spurred of the living room socket via a 13a FCU, the armoured cable is then run to a shed, were they used to have a lights. Now as the shed was rotten then have taken it down to replace it. This time they would like some sockets to run lawnmover ect.
what would be best option, take the armoured into the shed and terminate it into a small garage CU then have one lighting and one socket come out of it. change the socket MCB to a 10 amp in order to maintain discrimination.
There is a need to have and RCD as the house ring main that the armoured is connected to does not have any RCD protection on it as its an older board but still has more model MCBs on it.
Or
Would you take the Armoured into another FCU (in the shed) that then goes to a RCD socket. with a second FCU coming off load side of the first FCU fused down to 6amps for the light. But how would you then maintain discrimination between either ends of the armoured cable.
What peoples thoughts.
Or
