2.5mm earthing conductor from TN-S supply | Page 2 | on ElectriciansForums
Discuss 2.5mm earthing conductor from TN-S supply in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I have heard of earth conductors being left off all together, because when its added it starts tripping circuits, and if you add 16mm then it becomes your responsibility to fix. It may be it was the only size that didn't trip the circuits. Could open a can of worms. Just a thought, a bit of a dilemma.
Its not happened to me, but another spark mentioned it in a conversation, I thought it strange but as it may have been relevant I thought I would mention it. I did not ask what and how faults occurred but will get back to them and ask see if I can get a better explanation as how things were fixed. Sorry if I have confused anyone, not my intention, fore warned is fore armed I thought. Off to football now, 48 I should know better really, should stick to dominoes. cheers
I can see how disconnecting a faulty circuit from earth would stop it tripping an RCD as there would be nowhere for the fault current to go. This is obviously extremely dangerous though as there would be no fault protection and as the circuit is already faulty exposed parts would probably be live!!!
I think that swapping a short length of 2.5mm for a short length of 16mm though can have no effect. The difference in the resistance of a 200mm length of 2.5 and a 200mm length of 16 is of the order of 0.001 ohms, which is very insignificant compared to Ze. I think that the only difference is that if you short meter tails to earth the suppliers fuse will go bang before the earthing conductor melts.
hi guy's, i was told once by an edf dno engineer that no one but dno should really touch the main earth connection at suppliers side, PME or TNS, personally i'd put in a 16mm earth and leave cert. or you could call supplier of lecky/dno and report sub standard main earth.
10mm is the recommended size for TN-S, and is more than adequate by calculation so why bother with 16mm?
Reply to 2.5mm earthing conductor from TN-S supply in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Other way round, all line conductors are live conductors, but not all live conductors are line conductors. A live conductor is any conductor...
davesparks
Hi all, first post, please be gentle ;) Iv been involved in a bathroom refurb, nothing major, moving a light fitting and switch. My problem came...
