2.5mm flex or 6mm t+e | on ElectriciansForums
Discuss 2.5mm flex or 6mm t+e in the UK Electrical Forum area at ElectriciansForums.net
N
nathan-d1
Changing to built in double fan oven. 45A cooker switch which is supplied with 6mm from 20A mcb . Double fan oven is rated at 4.1kw.
4100/230=17.82
Would the flex be ok as it can carry up to 25A and less than a metre be used.
What do you guys suggest?
Needed to prove to the other spark that what i explained to him was right lol im sure that he either misheard and thought that i said 1.5mm. Ill find out and see if he says anything tomorrow
A lot of built in ovens are only 2kw - 3kw kind of area and many even come with 13A plugs fitted on flex.
4100/230=17.82
Do you mean a 2.5mm2 tri-rated flex which is also heat resistant, or a bit of 2.5mm2 ordinary household flex off the back of the van?
Reply to 2.5mm flex or 6mm t+e in the UK Electrical Forum area at ElectriciansForums.net
This charger doesn't support rear entry from the looks, only bottom entry, hence that. Unless they make a white sheathed SWA, I would still need...
I would put this down to 433.3.1(ii) - no overload protection needed because the load at the single socket can't overload the cable, being fused...
