N
nlbhoy
I was called in to a recently finished house extension as the heating wasn't working, plus they needed
the alterations tested for building control.
There was a kitchen extension to the back of the house plus a 2 store extension to the side which was an office downstairs, plus 2 bedrooms and a bathroom upstairs.
The previous spark has done a runner.
When testing the board there were 2x 32a breakers, one being the kitchen and utility ring which is all fine,
when I've carried out test on what appeared to be the second ring I've found that this is actually a radial, one of the legs appeared to be doing nothing, while the other 2.5mm is supplying 25 double sockets, over 4 upstairs bedrooms, downstairs office, lounge and dining room.
This is obviously a substantial area, there isn't likely to be anything power hungry used in these sockets, as it's TV's, computers with the odd hairdryer and vacuum being used.
Would fitting a 20a mcb be acceptable? so a 2.5mm radial on 20a mcb.
I'm a little concerned about the size of the area this is covering.
I'm not sure if this has been like this before the previous electrician had added on to the existing circuits,
or if he's split the ring main in some way were only one leg is now doing pretty much the full house.
Any help/guidance on what best to do here would be great.
