2 Circuits, 1 MCB | Page 2 | on ElectriciansForums
Discuss 2 Circuits, 1 MCB in the UK Electrical Forum area at ElectriciansForums.net
DanDobson
Good evening all,
I get a decent amount of work from a kitchen company and do all the electrical work for them.
As expected each one has its challenges, but this job i've looked at today has a kitchen ring on a 32Amp MCB, and its own cooker circuit on a 32Amp MCB.
Once I isolated the cooker circuit to start making the necessary changes, when I tested I am still getting 150v between live and neutral? does anyone know why this would be?
I have used my old and new Fluke meters and my martindale volt meter to check one or other wasn't failing.
With all the issues ive come across in kitchen re-wires, I haven't had this yet.
Any help and ideas would be much appreciated
Dan
Yes I have a very good idea, have you tested between cores with 500 volts? have you also tested continuity ? have you confirmed there are no joint boxes sending cables elsewhere off the main ring? lets get back to basics.
Lets get back to basics...? is there a need for that comment, ive sorted the issue with help from other users as I stated above... basically!
I think MDJ had overlooked the posts where you said it was all resolved when he posted this, it wasn't posted in any negative context its often a term used when the OP is getting muddled or confused with a problem.
As the original query is resolved I'll close the thread as there is no ongoing discussion taking place.
Reply to 2 Circuits, 1 MCB in the UK Electrical Forum area at ElectriciansForums.net
Thank you for your response. I really appreciate it.
Why not fit a self contained SPD fed directly from the Henley blocks, and free up a bay? Could probably make one up from whats there, using a...
2 3 4
4K
