U
ulluullu
I am in the middle of a new build house construction (bungalow) where the runs from the main consumer unit (if there is only 1)
will be in some cases nearly 60 meters of cable. So i was thinking, that it might be smarter to put a second consumer unit at
the other end of the house and run a *big* cable over to it from the supply, rather than running so many expensive long cables
for individual circuits. What i've read about is about installing a garage... but i'm thinking something a little heavier duty,
1/2 a house.
If anyone has any advise and thoughts about this, please.
To the same structure, i am installing the conductors for a lightning protection system, These are equipotentially bonded
to the steel structure, the rebar and about 10 tons of structural steel fixed to the bedrock. Would you connect the house
ground to the lightning protection ground? Or would you try to put a separate ground in for the house that would not spike
when the structure is being zapped by lightning? The building is on an exposed location in the inner hebridies, where it is
the highest point for miles - hence the LPS. In this regard, i am preparing to run a portion of the house electrics
using an inverter and renewable energy batteries as a lighting isolated electrical system; how would you establish the earth
for this subsystem (another separate earthing point?). How would you protect from lightning when you expect the house
to be struck once every 2 years?
1/2 a house.
