Dubster
I have a bit of an odd situation.
At one end of my living room there's a 2 gang switch and a light, at the other end of the living room there's a 3 gang switch and a light. Both switches control both, far end one also controls the light at the top of the stairs..
The light down the far end of the room works perfectly from both switches.
The light at the top end of the room works from both switches, but only if the switch at the far end is set in one of the 2 positions, if it's in the other position the switch at the near end of the room does nothing.
So, I took the near end switch off the wall to see if I could see anything untoward.
What I have :
Gang 1 - Yellow : L2, Blue : L1, Red : Squiggle sign (I guess that means common/power)
Gang 2 - Yellow : L1, Blue : L2, Red : Squiggle sign
On top of this there is then another mains cable that just has red and black.
The red has been joined up with Gang 2 Blue L2
The black has been joined up Gang 2 Yellow L1
Can anyone suggest why the switches are acting the way they are ?
Thanks muchly!
What I have :
Thanks muchly!
