2 gang 2 way | Page 2 | on ElectriciansForums
Discuss 2 gang 2 way in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I'd feed upstairs hall seperately from stairs so that if one circuit fails there should be some light available for emergency descent. Could be misplaced overthought .
Reply to 2 gang 2 way in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Double pole switches? Mounted on a grid module? Ignore the fact they have a N stamped on them. Or is your 2 gang switch decorative, and you...
"It works" and "it's safe" are not necessarily the same thing. With DIY work, they are often far from the same thing.
