P
parklane
Is there any such animal on the market as a 2 gang fused socket?
The reason I would like a 2-gang fused socket is to stop my student tenants using electrical heaters when I already supply gas central heating. I would fuse them at 3 Amps as they should only be used for laptops, bedside lights, and chargers etc. I could simply replace the existing 2-gang standard sockets. Any solution?
Why should a 13A socket outlet only be used for the appliances you suggest.The reason I would like a 2-gang fused socket is to stop my student tenants using electrical heaters when I already supply gas central heating. I would fuse them at 3 Amps as they should only be used for laptops, bedside lights, and chargers etc. I could simply replace the existing 2-gang standard sockets. Any solution?
