Guest viewing is limited
View the thread, titled "2 gang fused socket" which is posted in Australia on Electricians Forums.
3 gang sockets have to be fused. I want to know if there is such a thing as a fused 2 gang. The reason is I want to run a fused spur from a double socket but that double socket is already a spur from the ring. If I change the double socket for a fused socket then problem solved. Otherwise I have to fit another fused spur prior to the socket which is impractical in this circumstance.
There are some modular systems about, which might perhaps allow you to replace the first double socket with a fuse, switch and single socket?
Change the spured socket to a 3 gang metal box (a single box attached to a double box). Place the switched fuse spur up-line of the circuit.
Then spur away with your 13 amps innit.
hmmm. re-reading op's earlier posts. if you were to fit a fused S/O, be it 2 gang ot 3 gang, the fuse would only protect that socket outlet. it would not protect anything you spurred from it. your only optrion is to fit a FCU before the existing spurred socket. bit of hole bashing called for, methinks.
Interesting reply - surely the fuse in a 3 gang s/o would limit anything plugged in to the 3 gangs to 13A total, thus protecting the cable to the s/o?
yes, it would limit anything plugged into it, but not the cable spurred from it, which would be directly connected to the incoming cable/s.
Reply to the thread, titled "2 gang fused socket" which is posted in Australia on Electricians Forums.
