Hi all,
Hoping for some advice on whether what I'm looking for can be done - and if so how.
At present we have a 2 gang switch (it is a 2 way) with each gang controlling a single light fitting each.
The Live and Neutral are within the switch not the fitting.
I want to add another light fitting - but for this added fitting I would like to be able to switch it on from both gangs of the existing switch.
So basically;
1. If either gang of the existing switch in ON, the new AND existing fitting is on.
2. If BOTH gangs of the existing switch are ON, the new AND BOTH existing fittings are on without and problems with this arrangement.
3. If both gangs are OFF, the new AND existing 2 x fittings are off.
Also, I do NOT want to add a 3 gang switch. The existing 2 gang, 2 way switch needs to remain.
Hopefully how I've explained this is clear - any advice appreciated.
Many thanks
Lee
So basically;
Many thanks
Lee
