2 gang light switch to a smart light switch | on ElectriciansForums
Discuss 2 gang light switch to a smart light switch in the Lighting Forum area at ElectriciansForums.net
Tooter
Yorkshire
Hi looking for some advice if poss. Recently I purchased a smart switch to replace on in my man cave and I'm a little stuck on how to wire it up. It controls 2 lights no 2 way switching. I have attached 2 pics one of my existing switch and one of my smart switch all input is appreciated thanks.[ElectriciansForums.net] 2 gang light switch to a smart light switch[ElectriciansForums.net] 2 gang light switch to a smart light switch
If there are no other wires in your switch back box which maybe a neutral then no. Try Googling no neutral smart switch they are available.
Hi looking for some advice if poss. Recently I purchased a smart switch to replace on in my man cave and I'm a little stuck on how to wire it up. It controls 2 lights no 2 way switching. I have attached 2 pics one of my existing switch and one of my smart switch all input is appreciated thanks.View attachment 52698View attachment 52699
Think you will find that your smart switch will require a Neutral to ensure it will work.
Lightwaverf doesn’t require a neutral to work...
works through app, if you get their hub interface or with a handheld remote control.
The lack of neutral is one issue, another, it appears you have 2 feeds.
Hi sorry to keep thrashing this thred. If I was to run a neutral cable from the ceiling rose to the switch then ran both commons to the Lin on the smart switch would this still be safe and up to regs?.
I was actually thinking along those lines. If both switches are on the same circuit you could repurpose one wire as a neutral.
Reply to 2 gang light switch to a smart light switch in the Lighting Forum area at ElectriciansForums.net
brilliant thanks for your support. Lee
Neutral and live
