2 gang socket wiring. | Page 3 | on ElectriciansForums
Discuss 2 gang socket wiring. in the UK Electrical Forum area at ElectriciansForums.net
Mazak
Wolverhampton
Maybe obvious, but are any regulations how to fit earth cables?
They always say all must be terminated to back box.
So when 2 cables coming to the box 3 wires sleaved with green/yellow should be inside.
1 of them ending in back box?
Right?
I hope you understand me.
I will make picture later.
Really?? I can't remember a project that i've ever worked on from the 80's to the present where fly leads from the faceplate to the back boxes haven't been called for, and not just for socket outlets either!!
Which country do you work in, that is so uninformed? The design of U.K. 13A socket outlets is such that there is adequate contact, by means of contact to the metal bridgework behind the screws, and the fixing box metal screws. As there are usually 2 points of connection for cpc's inside a socket outlet, there is no requirement for earthing fly leads to the body of the box. This dates users of this practice, and probably went out at the same time as twisting cpc connections, and using a common sleeve.
Regards
Regards
you follow the spec you have been given or it will be charged for another company to correct it
Very cheap double sockets have one earth terminal, very cheap ones, 90 pence from CEF lol, most double sockets which are over a quid have 2 pmsl.
As I remember, high integrity circuits such as those for computers, with leakage currents in excess of 10mA require 2 points of connection for cpc's at socket outlets .......... and also at C.U.'s. Sockets outlets with one point of cpc connection, could not be used on a high integrity circuit. Now then, how would you cater for this requirement at the earth bar of a CU, and maintain the order sequence w.r.t. the Lives?
Regards
If a spec is issued calling for pigtails, a word in the ear of the specifier should be made, to have the anomaly corrected, especially if registration is applicable; if necessary get confirmation from a maker such as MK, the NICEIC or NAPIT. :coolgleamA: You may just get brownie points!
Regards
A word in the ear of the specifier should be made, to have the anomaly corrected, especially if registration is applicable; if necessary get confirmation from a maker such as MK, the NICEIC or NAPIT. :coolgleamA:
Regards
Regards
And what anomaly would that be?? It's a good working practice (now that is something that could be said belongs in the past!!). I take it you are far more qualified than Electrical design Engineers yes?? The very last people i'd take any advice from, is NICEIC/NAPIT or any other scam operator or indeed, anyone suggesting their advice to be sort/taken!!
Regards
Lol..I have always wondered that, as it puts it OUT of sequence
Reply to 2 gang socket wiring. in the UK Electrical Forum area at ElectriciansForums.net
Generally it would depend on the circumstances whether the armour is earthed both ends or not, and not just dependent on whether it's 2 or 3 core...
Being pedantic, the Crabtree 50A cooker switch is a 4500/1, which has 'cooker' printed on it. For a shower, you require the 4500, which is the...
