2 Inch PVC Conduits bending | Page 2 | on ElectriciansForums
Discuss 2 Inch PVC Conduits bending in the Australia area at ElectriciansForums.net
E
eng-ali
What is the Approved way to bend PVC Conduits of size 2 inch and more for any angle?
lower than 2 Inch conduits can be bent with a spring.
What for???
hi lenny
we were doing a milking parlour with with 6 different rooms, 3" trunking along the walls and used the 2" pvc adaptors an conduit to go through each wall to the other room and then carried on in 3". did think about cutting through the wall and continuing the 3" all the way but the finish on the walls were very expensive and didnt want to damage it. it worked very well.....
regards
gary
eng-ali
i have been sparkying in australia for the past 10 years since moving from scotland and we use 50mm pvc conduit alot, the easiest way to put sets into it is to get yourself a good heatgun and heat a large section of it while turning it to make sure it is plyable all the way round, dont heat it to melting point or it will kink, just make it plyable and start to set it gradualy, you will have to keep heating and bending and to keep its shape have a damp rag at hand so you can form it and not burn your fingers.
take your time as it does take practice, also form it on a flat concrete surface to save the bend from going off to one side.
hope this helps you out
Also over here we use 50mm flexible conduit for bits like that if you want to cheat..
eng-ali
But is heating accepted method for bending?
Reply to 2 Inch PVC Conduits bending in the Australia area at ElectriciansForums.net
Good question now to start with thermosetting insulated conductors are not tri-rated that is something different. Table 4E1A deals with this type...
You should have no problems with what you want but even if you install conduit the cable still needs to be UF cable which is approved for under...
