daiplayer
Is this a fault ? shouldnt resistancebetween live and nuetral be greater than this at the board ? (lightind circiut) some spot bulbs in (230v)....
Discuss 2 k ohm between L+E on lighting circiut in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
think he means r2
say that the op does this to his cct how would this reading make any diffrence for example if a bulb is still pluged in?
ahh i see cheers for tht IQ, the op said Kohms not Mohms am i correct in saying tht under 1Mohm is below the required reading by the bs7671
Reply to 2 k ohm between L+E on lighting circiut in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
