Hi all.
I’m currently wiring an S-Plan heating system (normally don’t get involved in this, but it’s been dumped on me).
I’m using a Honeywell DT90E room stat, and a Honeywell V4043H 2-port valve. In the room stat I’ve got A as live in, and B as live out (C not used, neutral not required), which is connected to the brown of the 2-port valve.
I’ve got 230v across the live and neutral of the valve, but the valve isn’t operating. The plumber who installed the system said to use A and C on the room stat, but what difference would this make to the supply of the valve? The DHW side works fine, it’s just the heating side that I’m having issues with.:banghead:
