K
Knobhead
Where can you see that?I could be wrong but it looks like its using a single phase to me off terminal 3 on km1?
Probably not much help either way!!!!
Learn to read a drawing. Control is from L1 & L2 = 400V
Learn a new thing every day.Learn to read a drawing. Control is from L1 & L2 = 400V
I can see it now but can honestly say I've never seen that type of wiring system before,always with a neutral.
Running a neutral is just a waste. Think, if it was a tidy sized motor would you want to pay for a 25mm 4 core when you can get away with 3 if you use a 400V coil.
That aside, control shouldn't be above 110V realy.
Yes that's absolutely true, but I have never seen single phase reversible motors in industrial power applications such as a ramp. This is why 3 phase is so widespread in industry; efficient power transfer; reduced cable sizes per kilowatt load and motor simplicity and reliability. In this instance, why not just replace/recon the motor?
Reply to the thread, titled "2 post ramp wiring 3 phase to single phase" which is posted in Commercial Electrical Advice on Electricians Forums.
