B
Blueflash
I have a recurant problem on a system which one inverter gets a AC fault. This happens alternately, either one inverter or the other. The fault seems to be at peak output but does not trip any breakers. The system is very wrong in the fact its all on the one phase (as only one available), but this should not cause an inverter drop out.
Both inverters are in close proximity before being joined at the meter itself, but I did not think this would be problematic?
AC cable run is 60m long and now has a total csa of 20mm due to two cables being utilised. This is adequate when run through Sunny Design.
So we are very confused.
Thanks in advance.
Thanks in advance.
