2 socket usb fitting | Page 2 | on ElectriciansForums
Discuss 2 socket usb fitting in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
If you mean your USB socket has 2 Earth connections left side and right then they are both linked together and the cpc(earth) can go in either side.
Is there only one cable at the existing socket outlet?
I can't remember if it was John Ward or Big Clive stripped a socket plate (may or may not have had integral USB). But the two earth terminals were not interconnected
Reply to 2 socket usb fitting in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
i am looking at outdoor security lights, hard wired with PIR sensors but there are so many options .. any suggestion on brand or what to get would...
Thanks a lot for the quick reply. I already have a good number of the 32A single gang connectors so I'll be using those on each individual wire...
