2 voltage bands, 1 double pole switch. Yes or No? | Page 2 | on ElectriciansForums
Discuss 2 voltage bands, 1 double pole switch. Yes or No? in the Australia area at ElectriciansForums.net
A double pole switch is clasified as a single switch. It is NOT classified or approved to provide a switching means for 2 separate circuits being in conflicting voltage bands... And you can take that one to the bank!! lol!!
This is a lash-up mate, you need to talk to this so-called engineer face to face. As i said, i'd want a written instruction to connect a 230V line and a 24V line to the same switch, end of!! Even functional connections in the same accessory back box, isn't exactly in keeping with band segregation rules is it??
Reply to 2 voltage bands, 1 double pole switch. Yes or No? in the Australia area at ElectriciansForums.net
It's a room where someone sleeps, so it's a bedroom. Minimum standards were set in the Parker Morris report in around 1963. Anything built after...
Only the N side of the lamp would be at 0v if you went further along the element the voltage would rise.
