2 way 3core strappers switches don't work as they should?? | Page 2 | on ElectriciansForums
Discuss 2 way 3core strappers switches don't work as they should?? in the UK Electrical Forum area at ElectriciansForums.net
I
ian65
Hi I have looked and tested a 2 way lighting in a domestic front room. When one switch is on the other can show 230 volts on all strappers and then in reverse when switched??
One switch is correct or the other depending on how it is switched any idea please Thanks Ian. :19: Should be simple!!!
Symtoms?
[ElectriciansForums.net] 2 way 3core strappers switches don't work as they should??
But as you say all strappers should all be live when on.
Reply to 2 way 3core strappers switches don't work as they should?? in the UK Electrical Forum area at ElectriciansForums.net
As above you will probably find the originals where oriented the same way and your replacements are upside down to each other, or visa versa. I...
Hello, Last year my 30 year old Static Pase convertor stopped working, the 3 phase motor is 0.55KW / 0.74HP and drives a small lathe. When I...
