2 way & intermediate pir is there such a beast | Page 2 | on ElectriciansForums
Discuss 2 way & intermediate pir is there such a beast in the Lighting Forum area at ElectriciansForums.net
A low level light on permanent ,switched to high level when activated .
CP electronics make sensors with all these functions that can be programmed by their remote. We use them all the time for warehouse lighting. What's described in the above posts is called step down illuminance.
10a 230v PRESENCE DETECTOR RECESSED - https://www.mylights.co.uk/p/PIRANDPRESENCEDETECT/CP-Electronics-PIR-Presence-Detector-Direct-Dim-Time-Delay/EBDSPIR-DD
CPE COMPACT INFRARED PROGRAMMIMG HANDSET - https://www.mylights.co.uk/p/PIRANDPRESENCEDETECT/CP-Electronics-IR-Programming-Handset-For-Presence-Detectors/UHS5
Obviously the light fittings would have to be dimmable to be compatible.
I may be wrong, but I thought as a PIR will turn on then turn off again, there is no need to wire it like a conventional 2 way system. Just take a PL to each one and then a feed to the lights. If any activates then the lights come on. When they are all timed out the lights are off. Or am I over simplifying it?
Good point, so if I have 6/7 switches to change over to PIR type switches in a stairwell in a small block of flats, obviously the first switch will have a permanent feed and switch line, but between that and the other switches are 3 core and earth strapper cables… So how would you recommend they be connected? One of the core’s say the brown could be carried over to each switch as the permanent feed, but which core would act as the switch line? If that makes sense… Would really appreciate it if could get back me.
Kind regards Daniel
Kind regards Daniel
I
Kind regards Daniel
Are you fitting pir in place of the switches? Do you have n at the switch? Is it a given that all lights are operated from all switches, or can you zone them?
I would remove switches, wago in on position, fit blanking plate, then remove each light fitting and fit a pir in best position possible. Refit light, then each light has its own sensor. Without seeing the layout and light positioning its impossible to know if this would work for someone moving around the staircase. As suggested earlier, it may be appropriate to fit dual intensity light fittings.
I
Changing the switches to time lag ones is a no-brainer.
No neutral pir wall switch sensors are available.
There is also the option of using wireless ones.
Reply to 2 way & intermediate pir is there such a beast in the Lighting Forum area at ElectriciansForums.net
My bafflement increases. I swapped the offending light with one elsewhere on the back of the house - one of those that's on a circuit of its own...
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
