Mjward
Don't know if it's because its Friday or a long week but my brains have turned to mush trying to figure this out.
In a nutshell: I have a downstairs hallway pendant with a 2-way switch. Fantastic. Well, no, both switches are on the ground floor. I want to add a switch to the top of the stairs (and at the same time add a second light fitting for stair lights). One of the switches is currently 2-gang (for hallway and landing) and that is the location I want to keep (and will make 3-gang to accommodate stair lights). The other switch is currently 3-gang (for hallway and 2 study lights) and I want to make it 2-gang for just the study lights and relocate the second hallway switch to the top of the stairs.
The problem: From what I can tell, it is the second switch, i.e. the one I want to (re)move that is the one with the feed to the hallway pendant.
I was wondering if the below would work:
1) Remove all hallway pendant wires from second switch (the one I don't want)
2) Then at that location, connect the wire that was in the COM terminal (and heading to pendant) into one of the wires that was in L1 or L2 (doesn't matter which) via a wago connector
3) At the first switch (the one that is staying) run a 3 core and earth to the new switch location. Connect the corresponding L1, L2 & COM together and then also connect the cable in 2) (i.e. going to pendant) into L2 on the first switch.
