sionevans
How should I wire a two way switch, so that I can switch it “on” at the bottom of stairs and “off” at the bottom of the stairs?
It is currently switching “on” and “off” using the right hand switch on the 2 gang switch - my preferred setup would be use the left hand switch.
However, the switch at the top of the stairs it not doing anything.
I have attached pictures of the back of each switch and the current wiring setup.
For context, I am DIY / Homeowner and currently replacing modern Lightwave switches, with older style MK switches.
