Am I right in saying, that if you have a switch wire and neutral at one switch and a feed and neutral at the other switch. You can connect switch wire and feed into commons, and then just a 2 core into L1 and L2
Discuss 2 way switching in the UK Electrical Forum area at ElectriciansForums.net
Feed = permanent live?and a feed and neutral at the other switch.
Yes only other way I do it is feed into switch 3 core between the 2 way and then sw at other end or same end. SW into common one end and joint through permanent live to go into common other end. Usually do this on ground floor flats to reduce the amount of cables going into light fittingsFeed = permanent live?
If so, and the neutral actually connects to the switch, not just a parking terminal, and we have a working 2w switching system, then the circuit must be the one I described, unless you know of another 2w arrangement where both live and neutral connect to a single pole switch.
I was talking about not having the feeds in the lights a hallway for example with 2 lights and one of those being operated via 2 way switch just found it easier taking feeds to switches and connecting through the switches2-way/3-way/n-way switching doesn't need any extra cables going to the light fittings compared to 1-way.
Am I right in saying, that if you have a switch wire and neutral at one switch and a feed and neutral at the other switch. You can connect switch wire and feed into commons, and then just a 2 core into L1 and L2o
Reply to 2 way switching in the UK Electrical Forum area at ElectriciansForums.net
