R
RedSnedd1903
Morning all. I have a problem on a Job were working on at the moment. I have a small toilet area fitted with a number of LED lights and an in line timer fan. They are both controlled from a 2 wire ceiling PIR. The problem is once the lights switch on initially the fan comes on also but once the lights switch off in the toilet ,the fan stays on forever. Even though the timers down to 1 minute. Checked the connections at the fan and they are correct although when the lights switch off I am still getting 50V on the switch wire. I am assuming this voltage is what is keeping the van running.
Thoughts anyone.
Thoughts anyone.
