Why does my 200di diesel engine start when cold first time every time and not start when hot ( completely flat battery symptom ) battery tested and ok, 14.6v on tickover all earths cleaned and re-seated, an extra earth from chassis to engine block, new starter motor, new starter switch, I have even tried the battery from my daily driver which I know is good and still get the same symptoms. Could it be the wiring from the starter switch to the starter motor breaking down which is the only thing I haven't tested yet?
Were is the battery located
Does it try to turn over when hot at all ?
Is the dash going dim/lights when trying to start ?
Have you a voltmeter ?
If it's pulling a good, fully charged battery down to 7.6 volts, then something is quickly going to get hot if it wasn't before. Between where and where is the 7.6 volts?
It could be that the engine is tight when hot ?
It could be the starter motor when hot ?
It is a brand new starter, new starter sw, all earths cleaned and re-seated and I even added an extra earth from chassis to engine block.
This is a fairly recent issue as it used to run without any problems?
It will run all day without issues, only issue is when trying to start again until it cools then starts perfectly?
You need to measure the amount of current the starter is taking when hot and if the engine is turning freely.
Stoke on Trent, Staffordshire.
United Kingdom
200di diesel not starting when hot?
Auto Electrician Forum
Thread Tags
Tags Tags
when
Diesel Donkey,
Diesel Donkey,
TrueNAS JBOD Storage Server
