230ac -12vac trannie | on ElectriciansForums
Discuss 230ac -12vac trannie in the Australia area at ElectriciansForums.net
sunny essex
Hi
when you suspect a faulty light transformer what voltage would you expect to be reading on the load side (12v) i have a reading of 2.9v do trannies just pack up completely or will you get low voltage readings below 12v
Rich
Hi
Rich
It must be a switch mode Power supply ( A transformer has two windings on a core )..The manufacturers should not be allowed to call them transformers when thy are NOT ( thats my rant over ) :mad::mad::mad:
Reply to 230ac -12vac trannie in the Australia area at ElectriciansForums.net
Hi Avo Mk8 Thank you so much! Yes the bulbs fit perfectly I don't think they are much bigger. I could have bought a bigger rated LED driver but...
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
