230V fan in Zone 1? | Page 2 | on ElectriciansForums
Discuss 230V fan in Zone 1? in the UK Electrical Forum area at ElectriciansForums.net
Hi all,
1st fixing a barn conversion at the mo
Builder has threw a spanner in the works and says the location of fan will now be in zone 1 near shower.
If it has to be selv then i will wire for a transformer. only snag is i allowed for standard fan and selv fan is a *** load more lol
the OSG says though minimum IPX5 with water jets and i was looking at this unit
XPELAIR DX100BT 100MM AXIAL BATHROOM FAN WITH TIMER. Free delivery! | eBay
what you reckon?
Well that''s down to interpretation, as it says IPX4 unless it is likely to come into contact with spray e.g cleaning. Now how many people up and down the country would not use the shower head to clean the tiles down? Not saying they will spray directly at the fan but near to it.
The fan identified in the OP is listed as IPX5 and so is suitable for use in zone one and in an area with water jets.
The thing to remember about water jets is that they are meant to be powerful and the spray head of a standard shower is not considered a water jet.
IPX4 means it can cope with splashed water from any direction so theoretically playing a shower on an IPX4 item should be safe ( I wouldn't risk it).
If you start considering the mobile spray head as the location of the shower then most of a small bathroom would be zone 1! It is the fixed outlet that is of relevance to the regs.
As you say, it boils down to interpretation, and what you are comfortable signing your name to.
IPX4 protected from water splashing for all directions
IPX5 protected from low pressure jets from all directions
IPX6 protected from high pressure jets from all directions
It is up to whoever is signing the paperwork to decide what a shower is classed as, not to really prove anyone is right or wrong, we will all have our own take on it.
To be fair I am not really comfortable fitting 230V fans in zone 1, particularly if it can be sprayed with the shower (kids might find that funny and a great game), so I would prefer to fit Selv, or if it really had to be 230V then IPX5 (unless the manufacture stated a particular type @ IPX4 was suitable for zone 1).
This is just my interpretation of things, and my personal opinion, others may well decide differently, me ? I prefer to err on the side of caution.
1 Protected against vertically falling drops of water (condensation)
2 Protected against drops of water falling at up to 15 deg from the vertical
3 Protected against drops of water falling at up to 60 deg from the vertical
4 Protected against splashing of water from all directions
5 Protected against jets of water from all directions (12.5 mm core nozzle, 10 m head at 3m distance)
6 Protected against jets of water from all directions (12.5 mm core nozzle, 10 m head at 1.3 m distance)
This is the Nics version, it is basically the same as that in GN1.
That one of yours Rich looks a more comprehensive version.
  • 17thpocketguide16.pdf
Just had a look at that pdf. ...Now in all my data relating to IP codes, the 3rd figure always relates to impact resistance!! What that NICIC chart is giving, is basically already covered in the dust protection chart....
That Nic chart is almost the same as the one given in GN1 E54,
Impact resistance is now given as IK codes (BS EN 62262:2002)
Here you go E54, http://en.hrlm.com/main/view.asp?id0=5&id1=5&id2=5&id=24
This has the IEC prefix
Edit: I also had a look at several different IP charts, and there is a bit of a variation between IPX4 and IPX5 descriptions depending whose chart you look at, I usually just use GN1, confusion abounds lol
Thats exactly my thoughts on it.
Thats why I chose the IPX5 version shown in link
Was curious to peoples thoughts
As D Skelton said earlier, the BGB 701.55 (viii) Ventilation equipment can be put in "Zone 1 according to the manufacture's instructions".
Devil's Advocate here... When I was growning up in the 70's the water pressure was very low and would take an age to fill the tub. I now live less than half a mile from where I grew up as a child and the water preasure in my home could strip the paint off a battle ship!
So, yes an IP X4 MAY be OK dependent on pressure and position of vent in respect to the shower head. But in my home you could argue that IP X6 would be needed because of the water pressure!
My take .... if the vent is above the shower head then IP X5. 2-3 feet away IP X4.
Like I said it's my take on it.
Reply to 230V fan in Zone 1? in the UK Electrical Forum area at ElectriciansForums.net
