230v mains to 12v or 24v USB | on ElectriciansForums
Discuss 230v mains to 12v or 24v USB in the UK Electrical Forum area at ElectriciansForums.net
Uk
Hi
Does anyone know a way this can can be done
I want to wire some usb sockets up the same type you can find in cars, up to a fused connection unit how do I go about doing this.
I know I will need a transformer of some sort but what's the best way to go about this.
I know some people are going to say why not just use the ones what come on sockets but that's not what I want so if somebody could help me out would be much appreciated
Example of the type of usb is in the picture I will attach [ElectriciansForums.net] 230v mains to 12v or 24v USB[ElectriciansForums.net] 230v mains to 12v or 24v USB
No if you look at the pictures I added you will see its a usb socket with two prongs on the end which I would like to wire to mains 240, I already have the items you have spammed on your post
You just need 12V power supplies of whatever rating is sufficient for the number of USB sockets you are using. 3A@5V USB output will probably require 1.5-2A@12V input so a single socket might be well served by a 2.5 or 3.3A adaptor like:
POWERPAX - SW3576 - AC-DC POWER SUPPLY, 12V 3.3A IEC 2.1 | Premier Farnell CPC UK
You can get up to about 12A @ 12V in the brick format quite cheaply which would power maybe 4-6 of your sockets. Crimp 6.35mm receptacles onto cables and common them together at the PSU.
It is, but from the OP and the type of product these units would be designed to fit in a vehicle dash and contain a converter from 12V to 5V with the current limiting circuit etc. Actually it doesn't give a spec for the input but almost certainly 12V.
If you already have the 240V to 12V adaptors which has linked to then why are you asking us to find you exactly that item?
Hooking usb to.12-24v is Nutty, ie you are ramming more voltage up some thing that thinks it's about to get 5v
So transformed then bridge rectifier a bit of smoothing then reg
Then hook ya usb contacts up
You will need to figure out what side is positive and ground
https://www.google.co.uk/imgres?img...sPMAhVkCcAKHX1VCJEQMwhSKCkwKQ&iact=mrc&uact=8
Read the thread properly, has has a usb power supply module with a 12-24 volt input, this module will have the requisite 5 volt output. he is not trying to create a 12-24 volt supply on a sub connector
I don't think we are reading the same thing
He has nothing... But wants to hook up the mains 240v, drop it down to 12-24v and chuck it out
Dosnt say he has any thing the pictures are examples
Also says he knows he will need a transformer
Need to read what Dan is asked and not everyone else
Cut the unwanted sockets off and wire your USB ones on.
Then cut the 13amp plug off and wire them into a 230v fused connection unit.
You were asking for power supplies, I thought you might have been able to work that out.
Reply to 230v mains to 12v or 24v USB in the UK Electrical Forum area at ElectriciansForums.net
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
Why not fit a self contained SPD fed directly from the Henley blocks, and free up a bay? Could probably make one up from whats there, using a...
2 3 4
4K
