2330 city and guilds papers
P
phil333
Has anyone done the 2330 papers (technical certificate) up to level 3 here?
if so... how did you get one?
i failed inspection and testing written but passed the practical and passed the rest YAY!:)
What a ---- course :confused:
Hi
Ive just purchased some papers from Bycon Ltd - Multiple Choice Test Papers Online For City & Guilds 2382 2391 2330 and 2377 only £1.75 each and they are pretty good,
papers 15,16,21 and 39...paper 21 is on motors only, a good one to practice on as this seems to be the area most people are struggling with.
there is one error on one of the papers regarding sychronous speed calcs but apart from that they are top class...
Got my exam next tuesday....have done loads and loads of MC papers..smartscreen, electrical quals.com etc
and also heavily revised motors so feeling pretty confident....just want to get it over with.
Upvote 0
Cheers pal ............. have got the link you mailed me.
I come from a sparking background, but jumped ship to telecoms 20-odd years ago. I am actually enjoying revising with my son, but feel there is a lack of practice papers/Mock papers available to get a feel of the sort of question that may be fielded. I dont mean I'd like him to learn parrot-fashion (that isnt the answer), I would just like more examples of how questions may be worded etc etc......
He too has done the Smartscreen and Swindon-massive, and purchased quite a bit of extra-curricular stuff. That info you mailed me sounds good for 'Motors', as this is one area that he (and I) are struggling to get to grips with.
Cheers again:D:D:D
Upvote 0
Hi
Are you able to upload these for us????
Upvote 0
I'm not sure I can try this for paper 21 and let me know if it works
user name bycon21
password Gde64HUt
Also try this link apparentley taken from last years question bank???
http://www.------.org/forums/forum/messageview.cfm?catid=172&threadid=19708
1.If a transistor is in saturated common emitter configuration, the transistor would be acting as:
a. a closed switch
b. an open switch
c. an amplifier
d. a speed controller
2.In group problem solving, what part would they be at where they decide which decisions they are going to use?
a. Storming
b. Norming
c. Performing
d. Forming
3.Where high voltage is being used in a factory, it should be:
a. Outside the working area
b. Incased in a concrete building
c. Suitably enclosed with warning signs
d. Outside the building
4.Where the wiring of a motor is through flexible conduit connected to earthed trunking, the earth connection to the motor:
a. Should be via the flexible conduit
b. Should be by a separate cable within the flexible conduit
c. Should be connected to a bolt on the motor
d. Should be connected to the earth terminal
5.If a design required that a speed of approximately 730rpm was needed to drive a piece of equipment, what type of motor would be required?
a. 2 pole
b. 4 pole
c. 8 pole
d. 12 pole
6.A sign with a white symbol on a blue background is:
a. Warning sign
b. Prohibition sign
c. Mandatory sign
d. Information sign
7.A worker who has been electrocuted is found to have a pulse but is not breathing, you should:
a. Call the first aid room for help
b. Give mouth to mouth resuscitation and get help
c. Phone for the emergency services
d. Start compressions to the chest
8.A 2Kw heater is connected to a 230v supply, the resistance in ohms of the heater is:
a. 0.115 ohms
b. 115.0 ohms
c. 26.45 ohms
d. 264.45 ohms
9.Whilst working below ground level, there is a possibility of a gas heavier than air present, the following PPE must be used:
a. A face mask
b. Hard hat and goggles
c. A respirator
d. A harness
10.What type of fire extinguisher must not be used on an electrical fire?
a. Dry powder
b. Carbon dioxide
c. Foam
d. Water
11.A type of capacitor that has rolled sheets of thin aluminium around a core is known as:
a. An electrolytic capacitor
b. A polycarbonate capacitor
c. A ceramic capacitor
d. An air gap capacitor
12.When a fire drill has been organised and the alarms sound, you should:
a. Check with your supervisor that it is a drill and continue work
b. Ignore it
c. Stand by the fire extinguishers
d. Evacuate to the designated assembly area.
13.An AC circuit has an inductive reactance of 13Ω, a capacitive reactance of 23Ω and a resistance of 18Ω calculate the impedance of the circuit.
a. 424Ω
b. 4.97Ω
c. 20.59Ω
d. 1.6KΩ
17. An AC circuit of voltage 230v at 50Hz and has an inductance of 0.1H and a resistance of 28Ω, calculate the total power in the circuit.
a. 928w
b. 1.25Kw
c. 1.89Kw
d. 0w
14.An RCBO works on the following characteristics:
a. Magnetic only
b. Thermal and mechanical
c. Mechanical and magnetic
d. Thermal and magnetic
15.When a diode is connected across an AC supply having a peak value of 5v, the peak inverse voltage across the diode is:
a. 0.7v
b. 5v
c. 7.07v
d. 10v
16.The Aims of the Disability Discrimination Act is to give disabled people rights in terms of:
a. The right to more breaks at work
b. Replacing the amount of disabled people in society
c. Employment and access to goods and facilities
d. Lowering the entrance skills necessary for employment
17.Permits to work are issued by:
a. A health and safety officer
b. The person in charge
c. A designated responsible person
d. A competent person or persons
I havent got the answers to these but post your answers and then we can compare????
Upvote 0
1-c
2-b
3-c
4-b
5-c
6-c
7-a
8-c
9-c
10-d
11-a
12-d
13-c
17-b ..... Be aware there are two Q17's.
14-d
15-d
16-c
17-c
Hope this helps pal ................ cheers for your input on this.
Upvote 0
Checked out a couple more of those bycon things if people are interested:
Paper 22, transformers etc. - username: bycon22, password: fs4EF57Gh
Paper 26 - 3 phase etc. username: bycon26, password: ht90Ngs3
Hope they help
Upvote 0
Just off to do my final 2330 301 unit 1 multiple choice tonight KO 6pm........tell you all what its like in the morning!!!!!!!!!
Upvote 0
Well everyone the good news is that the 301 exam is not that bad....all I would say is that believe it or not the tricky questions are the health and safety ones....but thats only probably a couple of them and its really not worth reading the whole H+S unit just to get a couple of extra marks........
I'm all done now, 17th edition update on the 24th June, then relax for the rest of the summer and finally 2392 in sept....don't know what i'll do with myself on tues and thurs evenings now???
Upvote 0
Electrical Courses
