Hi there. I am a student part time for level 1 &2 in UK. I will have an exam 2382-622 but I stuck to one of the questions. Actually when I looked for information around and make some thinking about it I think the answer would be,B - Maximum demand, because everything else can be directly measured or calculated. Am I right with that though.
I don’t know why the picture can’t be attached. The answers are
A- nominal voltage
B- maximum demand
C- prospective fault current
D- earth fault loop impedance
I had to open this sait throgh the computer. So here are the picture ofte question and page 510 from BS7671. Nominal voltage,PFC and Earth fault loop impedance are characteristics of the supply. Maximum demand is characteristic of the load but the question here is - Which characteristic of a public supply can ONLY be determined by enquiry? So here isn't importatnt what is included into the characteristics of the supply,they asked only which of them can't be measured or calculated and only can be achieved by enquiry. This is the way that I understood that qiestion. If the maximum demand isn't supply characteristic so we can exclude it from that, because they asking about the characteristic of a public supply. I hope now everithing is clear. What are your assumptions?
Edit i saw it . There is a little note under nature of supply parameters. Number 1 can be determined only by enquiry,an number 2 enquiry and measurement. So by enquiry Nominal voltage and Nominal frequency, and because there isn't Nominal frequency among the answears the correct answear is Nominal voltage. Someone here led me to that conclusion on previous posts. We can measure the voltage but we wouldn't know that this value is the correct value before it be confirm from power company. Alright guys , thank you about your help. Now I am ready for the tomorrow's exam- I hope :)
Upvote 0
All the best in the exam.
Understanding how the questions are worded and what is being asked of you is important in your future exams.
Pleasure to assist. The key word is Nominal. Taking time to understand the reason will serve you well.
Upvote 0
I did it guys. Actually this was my second attempt because the first one was fail. I was pretty sure that I had found at least 50 from 60 answers in direct text into the book. There was a technical error at the end of the exam but it seems it was uploaded. After it all system went down and we were unable to do the next four exams. About me sometimes was wrong and about that it was failed. After that I did four times 2382 exams in home and the lowest result was 73% . Today on the sheet was marks achieved 55.000 . I am not sure what does it mean- 55% of 100 or 55 correct of 60 . I can’t believe this is percentage but I don’t know. At least it is successful 🙂
Upvote 0
Corby
United Kingdom
Trainee Electrician
2382-622 exam question
Electrician Courses : Electrical Quals
Thread Tags
IvayloP,
ahmed1963,
Electrical Courses
