swifters
Just done my 2391-10 and found it pretty tough.. Anyone else out there do it tonight? What is a statutory document that governs the distribution network? Is it the electricity at work regulations?
How did people find the exam who sat it tonight? I didn't like the question regards what are two supply characterisics that can ONLY be found out via enquiry to DNO? Seems a bit ambigious. The Voltage drop calculation was resistance x amps right? Seemed a bit simple for 8 marks!
With the dno question i put, type and rating of suppliers protective device.
and for the volt drop i did exactly the same and was wondering the same thing 8 marks for such an easy question :S
Wow, I'm actually starting to think I did really good in this paper! There were a few questions that were deliberately designed to catch you out, i.e: -
Insulation resistance tests, what test voltage would you use for these circuits operating voltages: -
550V AC
250V AC
25V AC
I nearly put down 250V for the last one, then I remembered that that was only for testing SELV or PELV so I bounced back to 500V DC!
In part 2 there was 30 marks allocated just for describing how to do the following tests: -
1.) Continuity of protective conductor on a radial lighting circuit.
2.) A Ze test.
A further 15 marks for drawing the earth fault loop path for a TN-C-S system. I figured that was an easy 45 marks to be honest.
Hi Des 56 if u look eic on the supply characteristics under nature of supply parameters,on the notes
if u can read it says 1 by enquiry 2 by enquiry or by measurement.
