2391 question | on ElectriciansForums
Discuss 2391 question in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
wrighty
leeds
calculate, using the data below, the earth fault loop impedance of a radial circuit using 1.0mm conductors, for line and cpc, show all calculations.
ze= 0.09
cable length=10m
conductor resistance=18.10mohms/m
struggling with this question and havnt a clue where to find the formula/equation, i dont want the answer just how to work it out cheers
yeh i got it at that but i get the jist, thanks alot lads, struggling a little with these calculations etc, but only had GN3 a week, n just 5 weeks to go untill my exam, gunna av to really knuckle down n get em cracked off, be eating drinking n sleeping formulas,
Upvote 0
I think the 18.10 m/ohms is for one conductor.
I dont have material to hand to check but seem to remember 1.0mm T&E having an R1+R2 of 0.036 odd ohms per metre.
Upvote 0
Wrighty just keep your cool in the exam and try not to worry too much (easier said then done). I was in a class of 10 and only 4 of us passed! Alot of these guys worried them self so much and flapped that they cost themselves a lot of time with just worrying. Answer a question then move on and stop worrying about it. You will have time to go over them after im sure, but get SOMETHING down first.
As others have said read GN3 till your eyes bleed, then keep reading at every opportunity. The biggest problem with this exam is that it does not follow a pattern from year to year. Every year the questions differ alot. No amount of 'past papers' is going to show you what questions will be in your exam, just learn the main formulas, the rest of the information will be given to you in the form of tables.
On my B question i had a scenario of a garden lamp post wired into the house and all questions in part B were on that, cpcs, cable calculations, right methods of erection. Just a tip in part A you will probably be asked about different parts of a supply from generator at power station to end loading equipment. Do a full diagram and make sure you know the correct terminology because they mark you down for using wrong terminology so you can really gain some marks on a clear CORRECTLY labelled diagram. And CORRECT terminolgy in the whole exam can really get you marks.
Last bit of advice, if you dont have it yet, the 2391 city and guilds exam book is a must. tells you what to expect in the exam and the layout of it, then couple of practice questions. i advise it.
Good luck with it mate, im sure your pass, just stop worrying:)
Upvote 0
Reply to 2391 question in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
He is after the four options for 1 and 2 of the multiple choice exam, probably optimistic someone will know this. Your question 3 in incomplete to...
It was a one time £19.99 fee. I'll be reaching out to them though to get that back. It was the only online extensive bank of questions that I...
As long as the heat input is greater than the heat losses from the container and the resistance is sufficient to limit the current to no more than...
davesparks
Read up on the definitions of conductors, then circuits. Then double check what bunching is defined as - and the answer will be apparent PLUS...
Definitely the radial, we were talking about and discussing different size cables for the different circuits. I have made some amendments to my...
9K
Electrical Courses
