2391 | Page 2 | on ElectriciansForums
Guest viewing is limited
Discuss 2391 in the UK Electrical Forum area at ElectriciansForums.net
sparky71
Sat my 2391 in aug got the results back over the phone failed
Did not say what area I failed on
Is there any way to revise and remember all gn3
No worries.....all broken down its not bad at all just all in one go seems a bit daunting, just go for a little bit of a time at revision. One test procedure each night and you will blast it!
Then section A just little stuff to boost your marks I.e Minor Electrical Installation works certificate instead of minor works
don't forget the 3 seperate documents after a installation is Electrical Installation Certificate, Schedule of Inspections, Schedule of test results
Check sharp edge on Conduit, inspection lids secure, conduit screwed up correctly,......that's another 3pointer
Your maxium zs for each different type and size of breaker are on what used to be page 49 of red regs but will have to check what page green.....think like page 53
You can calculate your zs by taking your R1 + R2 value of a circuit and adding that To your Ze (reading from consumer back to sub)
Reply to 2391 in the UK Electrical Forum area at ElectriciansForums.net
The coding part is all down to experience and knowing whether something is right or wrong. Remember some pics have no faults.
My older card has it but my newer card doesn’t
Recommended Sponsor News
Hi everyone,
