2394/95 this week
R
richard7467
Anybody taking the 2394/95 Tuesday and Wednesday? if so where have you concentrated your revision? I've tried to cover over the whole spectrum but feel that I maybe glossing over some points. I do know that a banker question(so ive been told) will be to explain with the aid of a diagram the earth fault loop on a given scenario and explain the faults on particular set of example results.
Alot of questions on Initial verification, No Earth fault path on lighting circuit drawing which i was ****ed off about, 11 pointer for explaining Insulation Resistance test, some chap on the same course did the 2395 the night before and said it was easy, everybody walked out the 2394 exam saying that it was hard.
Also Exam is only 1hr 30 mins which to me seems to short unless you can answer every question without thinking, you use to get more time in the 2391 but seems to be same amount of questions involed.
Upvote 0
Electrical Courses
