2395 Practical | on ElectriciansForums
Discuss 2395 Practical in the Electrical Course Trainees Only area at ElectriciansForums.net
jimmyray
Trainee
Exeter
Hi folks, I've got my practical exam for the 2395 next Thursday. Anyone got any tips/advice/words of wisdom to help me along? have been studying pretty hard for this and have passed the multiple choice and waiting on results for written, so this is the last piece of the puzzle!
Cheers
Jim
Firstly good luck with the practical, I hope it goes well.
Get some practice in beforehand so that you are confident on the tests required.
You will have plenty of time for the inspection and test if you proceed logically.
Get all the installation details (earthing, bonding, tails size,main fuse, main switch, circuit list, etc) down on your sheet first so that you can ensure everything is covered.
Always perform complete safe isolation before starting work on the installation.
Remember that inspection precedes testing and that the installation should be visually and tactilely checked for errors prior to starting testing.
Understand the reasons for testing and the sort of levels of results you would expect so that you can immediately correct if a result is strange.
e.g an R1+R2 of 4.5 ohms, hang on, stop, I am measuring the resistance of copper conductors over reasonably short distances, this should be in the region of tenths of ohms, what is wrong, oh, the crocodile clip has almost slipped off, sorted, carry on.
Periodic inspection should not require too much in the way of dismantling, inaccessible items are not covered by a periodic inspection so you do not need to know if the cable is run correctly in the wall, for example.
Insulation resistance tests should be performed with the cpc still connected to the earth bar so you are testing live and neutral to earth and not to cpc only.
Be calm and collected. You know how to do it all. Just carry it out as you would in the workplace and be methodical and thorough.
Best of luck with it mate. I am sure you will be fine. All worth it to hold the certs at the end of it all.
Found out today that I passed the written exam! 2395 certificate coming my way :rockon2:
Thanks to this forum - has been a massive help. Now to finish the 2357!
Cheers Leo, put the work in and it'll pay off mate. Once you finish level 2 the fun really begins! I've found this forum to be a great aid to studying, so don't be afraid to ask loads of questions.
Reply to 2395 Practical in the Electrical Course Trainees Only area at ElectriciansForums.net
