K
kombiklassic
Hi .. New on here and green as hell...
I am trying to actuate a 1,2 air valve with a 24v dc solenoid through a 24vdc relay block via a plc ...
i have tried to switch the live , the neutral.. i have tried 110v 240v solenoids and now a 24vdc but as soon as i connect everything up and the relay gets its signal the machine is tripping??? I have used the same set up else where on different machines and it works fine? so what am i doing wrong?
please help this non starter...
