Hi everyone,
I was wondering if I could get a little advice on a small project I plan to carry out over the next few weeks.
I plan to install 10x 6w GU10 LED bulbs (fitted inside some suitable outdoor light boxes) on each fence post along a 30 metre garden fence, the lights will be powered from my shed where I have an existing modest 12v solar installation.
The shed has a 20W solar panel, 2x 12v 12Ah batteries wired in parallel for 24Ah total, a solar charge controller (cheap Chinese one) and a 12 to 24v boost converter.
I plan to use 24 volts for the fence run.
My question is, should I connect all of the lights in series or parallel? I'm leaning towards parallel because I'm worried that if I connect them in series the current would drop along the cable causing the end lights to dim. Plus the GU10 bulbs are rated as 12 - 24 volts so would presumably be happy about a little voltage drop under 24 volts.
I decided to get the 12 to 24v boost converter because I was worried about the voltage/current drop and due to the length of the run at 12 volts I would need thick expensive cable.
However, before I start my endeavor I'd like a little advice from anyone who has done something similar previously.
Thanks.
Thanks.
