View the thread, titled "25mm armoured" which is posted in UK Electrical Forum on Electricians Forums.
W
wellshocked
was just wondering if this was the correct size, any help would be appreciative
a 25 mm armoured with a run of about 25 metres , ambient temputure 25degrees, clipped on its own direct to a wall.
it is feeding a supply of a 100 amp switch
someone told me it should be downgraded to a 80 amp , but i cant see whats wrong with it being as it is.
also , i been told that you have to earth cable tray, i always thought that if it was rcbo protected you wouldnt have to do it , am i wrong?
cheers
How do you connect swa securely without a gland? Does it just go through a rubber grommet like a piece of flex?
I can't see how terminating cable into the box on the unit would invalidate the warranty tbh
Reply to the thread, titled "25mm armoured" which is posted in UK Electrical Forum on Electricians Forums.
