25mm PVC Channel
P
pauldreed
I'm using lengths of 25mm PVC channel to bury some cables in plaster/breeze, but despite trying several nail sizes, the channel keeps splitting & cracking when I secure it.
What nails are recommended to avoid this please.
Paul
Steel capping, sharp edges doubled over. Clout nails at the side of the capping. if the mortar is crap a 5.5mm hole drilled into the brick or what-have-you with 3 or 4 clout nails crammed in! Job done!
If you are going to the trouble to drill a hole, put a red plug in and clout nail in that.
plasterers clout nails as said previously, tried every thing else without much success recomend difetent sizes if going into render with brick. to stop capping splitting you could puncture holes first on flat surface like a peice of wood.i
