Specialist
Hi all: Not got Regs book here & can't for the life of me remember the max length of Run for 25mm tails installed in trunking to feed a CU.
Discuss 25mm Tails in Trunking in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Pretty sure its not in the IEE regs, its a supply authority regulation.
Just a preference, they're double insulated. It's just giving a bit more support to them.Is it a requirement to run tails in trunking then? Or just a preference?
You are of course correct. I stand corrected Sir.top,
they are not "actually" double insulated.
They are technically insulated & sheathed.
The "grey" covering on T&E & tails is not classed by the cable standards, nor the cable makers as insulation!
top,
top,
Reply to 25mm Tails in Trunking in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
