28A in 4mm cable 6.5kw hob | Page 2 | on ElectriciansForums
Discuss 28A in 4mm cable 6.5kw hob in the UK Electrical Forum area at ElectriciansForums.net
Portsmouth
i need to wire in an induction hob which is 6.5kw and the cable already chased in is 4mm and would be a real pain to replace for a bigger. I just wanted to know if it would be alright or play it safe with a 6mm?
The hob being 6.5kw - but what would it actually draw?
I've just been working on a kitchen where the customer sourced, induction hob, came fitted with a 13A plug!
Had one last month murdoch it was a siemens 4 zone and i was only armed with a cooker outlet plate :rage:
Change the out let plate for a socket. Simples
and i did after an unwanted trip to the wholesalers
Reply to 28A in 4mm cable 6.5kw hob in the UK Electrical Forum area at ElectriciansForums.net
I actually did it with a 4 core 4.0mm swa last week!
I believe the 6mm and 40A MCB debate is a little contentious at times. It depends on the installation method, being pretty close to the tabulated...
